local variable or queue with one value
1) You can eliminate a lot of your code by using the Data Queue PtByPt VI.
2) You can simplify things a lot by using a State Machine.
3) You can eliminate some of your constant setting of properties by using an Event Structure.
Message 11 of 11
(1,128 Views)
