lock in amplifier based on NI DAQ card and LabVIEW software
I want to complete a lock-in amplifier based on NI DAQ card and LabVIEW software. Is that possible?  Anyone ever did that? I didn't know the main problems doing this work. Maybe the sample rate of the DAQ card should be high cause the target frequency I want to lock is about 40KHz. Thank you.
(4,127 Views)
Yes, it can be done.  I do not know if it is still available but there was a lock-in toolkit.
You definitely need a high sample rate.  You will need to get multiple samples per period of the signal frequency so that you can get good phase resolution.
Lynn
(4,089 Views)
(4,075 Views)
Thank you very much.
(4,056 Views)
Can you give me a example about how to choose the sample rate of the DAQ card? Thank you!
(4,053 Views)
johnsold already wrote you that. You just need to decide what is a good resolution for you. 10 x 40 = 400 kHz ? Or even higher? So I guess a hardware capable of 1MHz sample rate should be ok...
(4,035 Views)
