log temperature and voltages acquired by DAQ
I tried using the RMS.vi in Math > Prob & Stat palette last week and the results were not the same.
Message 11 of 12
(541 Views)
Do you have integer numbers of complete cycles of the signal in each block of data sent to the VI?  RMS VIs can produce widely varying outputs when fed different phases of a fractional cycle.
Lynn
Message 12 of 12
(530 Views)
