loop in subVI to be stopped by control in calling VI.
Try the following vi's, I've changed the Ring control to an Enum and added an initialise option.
Message 21 of 24
(788 Views)
It still does not work. I tried with a global variable, and that did not work either. The problem is that values are not checked in the main Vi while executing the subVI.
Message 22 of 24
(776 Views)
Exactly!  I mentioned this in an earlier post.  You have only posted an image of a small portion of your main VI so we do not know what is going on there.  However, I infer from some of your comments that that is where the problem really is to be found.  If you think about the dataflow of the main program, I suspect that you will find that the stop button is read long before the looping VI runs and never gets read again.  In this case it cannot possibly work the way you want.
Try turning on the highlight execution (the light bulb on the block diagram toolbar) and watch what happens.
Posting your main VI would help us see what is going on.
Lynn
Message 23 of 24
(766 Views)
Lynn
Yes!
The light bulb is your friend.
Ben
Message 24 of 24
(764 Views)
