looping through data files in a folder
I need to look at several files of data. How can I loop through all the files in a directory in order to get the data from those files?
Thanks very much
(7,191 Views)
Build an array of the file names in the folder you are interested in, using the Advanced File Functions "List Folder" under File I/O, then index through the file names (a while loop possibly) where each file name will be used to perform whatever function(s) you are trying to perform.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(7,181 Views)
Accepted by CRivett
An autoindexed FOR loop would be the way to go.  As already stated, use the List Folder function to get a list of the files in the folder.
(7,148 Views)
Thanks a bunch! Both posts were very helpful!
(7,143 Views)
You can use either
a. List Folder Function OR
b. Recursive File List VI
Later is useful if you have nested folders containing data files, so you can input the top level directory and this VI will output all files in that folder or any sub-fiolder.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(7,137 Views)
