lost functions palette
I am using dual monitors.   Sometimes I loose the fun ctions palette as if it was on another part of the screen I can't see.  Selecting the funtions palette under the View menu on the block diagram does nothing.  Even after restarting LabView I still can't find it.
(4,864 Views)
What happens if you right click on the block diagram?
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,856 Views)
When I right click on the block diagram I see the functions palette but then it goes away as soon as I click anywhere else.
(4,846 Views)
Accepted by JohnP
In the upper left hand corner of the pallette there is a push-pin. Click on it.
Message Edited by GovBob on 12-22-2009 04:04 PM
(4,843 Views)
Here is some other info for reference
LabVIEW 2009 Help - Functions Palatte
Why Am I Unable to Add an Item to the Favorites Category in the LabVIEW Functions Palette?
(4,811 Views)
