lots of property change via refnum
I've a big cluster of commands dispayed on the screen and want to change a lots of colors.
The probleme is that at each property change the cluster is refreshed.
I would like to change all the property I need and then make a refresh.
Is there a way to do so ?
thanks
(2,799 Views)
The property "deferPanUpdts" will stop screen updates when set true, and will enable them when set false.
See attached jpg.
Note: In LV 7.0 an additional screen update occurs when the defer... is set to false, and THEN the updates are defered.
Ben
(2,788 Views)
My Bad!
The second DeferPan... should have a "FALSE" constant.
Ben
(2,786 Views)
search for defer updates
this option defers frontpanel updates
I believe an example is somewhere available.
greetings from the Netherlands
(2,785 Views)
Thanks to all
i have foud it.
(2,776 Views)
