loudness scaling of time varying chirp signal
Hi there
I have an audible chirp signal program on labview which produces an audible linear swept sine signal. This basically runs from my computer and through an audiometer where I can control the intensity of the signal. The problem is I have no idea of how to scale the signal so that it is equally loud along the entire sweep duration. Does any body have any ideas on how to create the sweep so that it is heard equally loud with reference to the fletcher munson curve? Or what steps need to be followed for this type of set up? It doesnt have to be perfect, but close enough.
Thanks so much
Anthony
(3,418 Views)
Anthony,
I would consider digitizing the equal loudness contour curves. Use a table lookup to multiply the signal amplitude at each frequency.  The desired loudness would select a row from the table and the current frequency would select a column.
I did something similar to that in LV 1.2 to compensate for differences in amplifiers and speakers.
Lynn
(3,406 Views)
Hi!
Can you please attach the same file but converted for Labview 8.5.1
Thank you!
(3,252 Views)
hello,
here in 8.0
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,246 Views)
to obtain such a thing you have to consider frequency response of your global sound generation :sound card, speakers  and to correct it also
regarding the human  ears
Regards
Tinnitus
(3,237 Views)
Hi!
Thank you very much. But the copy that you attached yet seems to be the later version and my 8.5.1 does not open it. I am also looking for correction methods to compensate the power of chirp in second pass.
regards,
Diwaker
(3,234 Views)
this should be the right one
(3,230 Views)
