09-30-2010 02:45 AM
Hi there
I have an audible chirp signal program on labview which produces an audible linear swept sine signal. This basically runs from my computer and through an audiometer where I can control the intensity of the signal. The problem is I have no idea of how to scale the signal so that it is equally loud along the entire sweep duration. Does any body have any ideas on how to create the sweep so that it is heard equally loud with reference to the fletcher munson curve? Or what steps need to be followed for this type of set up? It doesnt have to be perfect, but close enough.
Thanks so much
Anthony
09-30-2010 07:49 AM
Anthony,
I would consider digitizing the equal loudness contour curves. Use a table lookup to multiply the signal amplitude at each frequency. The desired loudness would select a row from the table and the current frequency would select a column.
I did something similar to that in LV 1.2 to compensate for differences in amplifiers and speakers.
Lynn
04-05-2011 10:47 AM
Hi!
Can you please attach the same file but converted for Labview 8.5.1
Thank you!
04-05-2011 11:22 AM
hello,
here in 8.0
04-05-2011 11:33 AM
to obtain such a thing you have to consider frequency response of your global sound generation :sound card, speakers and to correct it also
regarding the human ears
Regards
Tinnitus
04-05-2011 01:21 PM
Hi!
Thank you very much. But the copy that you attached yet seems to be the later version and my 8.5.1 does not open it. I am also looking for correction methods to compensate the power of chirp in second pass.
regards,
Diwaker
04-05-2011 02:52 PM - edited 04-05-2011 03:01 PM
this should be the right one
