low performance on 2d array operation
Also note that you have of course 8 surrounding pixels, not just 4.
You also need to possibly correct for edge effect if indexing outside the valid data area.
Message 11 of 14
(1,653 Views)
Images I'm looking at in my experiment occupy roughtly 1/3 of the sensor area, in the center, and features are usually about 6*6 pixels large, so using 4 or 8 surrounding pixels won't make a huge difference. Another camera I use has this filter interagrated and it uses 4 pixels, so for the sake of consistency I'm probably going to use only 4.
Message 12 of 14
(1,648 Views)
I am not sure if it was suggested before in the posts, but for such image processing tasks a video card is a very good candidate.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210829
Depending on the 2D array size, you can get nice performance increase.
Message 13 of 14
(1,629 Views)
@MF0088 wrote:
Indeed the operation is done in 2-3 seconds on my desktop computer using shift registers.
Thanks for you help here.
I know the code is abolutely not optimized regarding boundary conditions, if 2 adjacent pixels are deffective and number of times I call Increment or Decrement, but it was a rapid VI I made on a test file that could not fail these tests. I will work on that but I know how do it it.
For what it's worth, here is what I have now, as a working solution.
If you do the Filter comparison in the inner loop you don't need to create a 2D-array, which should be slightly better. You can also change the Quotient&Remainder to a Bitshift 2 right (same as divide by 4) for some speed optimization.
Also, do one +1/-1 and split the wire. It's not many clock cycles difference, but out of principle. 🙂
The Indes array don't need the 0- and 1-indexators, it's the default.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 14
(1,625 Views)
