lower and upper limit on graph - LabVIEW NXG 3.0
Hello
I have a question regarding LV NXG graphs.
I have this situation, on figure 1 I request a short amount of date from my DB, and as far as I can tell, it is working fine. On the other hand, on figure 2, I seleted a large amount of date, so we made a logic to only show the mean based on one hour. In this case, my upper x axes limit gets a lil messy.
Do you have any idea how limit axes on LV NXG running a webVI?
(4,197 Views)
Hey Granado,
What exaclty do you mean when you said the limits got messy?
Regarding the X axis, have you checked the axis settings for the graph control in webVIs?
Felipe Flores
Technical Support Engineer
(4,127 Views)
I needed to look very closely at the images to understand the problem.
You have set the end time of your Graph to 3:something PM. This corresponds to the right-most tick on the X Axis. Unfortunately, the Label associated with this says 11AM, which should be the label of the tick just to the LEFT of the last one. Correct?
(4,102 Views)
Hello Intaris
Actually I figured out that I had a problem related on how my LV 2016 reads the data from my sql database.
This issue led my string to timestamp VI to convert my date wrong.
(4,097 Views)
Accepted by Granado_93
Hello FloresFe,
(4,095 Views)
