lv 8.5 bug or dsc 8.5 bug
I've created a dsc 8.5 project with thousands of shared variables distributed in 12 libraries. Every shared variables has the description parameter enabled (the description beeing a string meaning an index number in the system).
 A vi register the shared variables for event structure (data updated event). When the shared variable has data updated event the description of that shared variable is read through property node. In labview development system everything works fine, but when the application is built the property node return empty string every time for every shared variable.
cosmin
(8,203 Views)
Hi cosmin,
I get the error, "Error -1967362020 occurred at Property Node...The provided refnum is invalid," when I try to run it in an executable. Do you receive the same results? Thanks
(8,129 Views)
yes, I received that error on every read through property nodes
cosmin
(8,123 Views)
This was reported to R&D (# 4FTC7ETM) for further investigation. A possible workaround is to use extra Shared Variables to pass around the Description information. Thanks for the feedback!
(8,090 Views)
"This was reported to R&D (# 4FTC7ETM) for further investigation."
Thank you Mike!
You could not possibly be serious with that work-around (I hope).
Ben
(8,080 Views)
Hi
the workaround for me is the use of variant datatype for shared variable and description as an attribute
cosmin
(8,069 Views)
Thank you!
Ben
Message Edited by Ben on 12-01-2007 10:08 AM
(8,008 Views)
