lvalarms.dll crash
Hi everybody
     I tried to find a solution for this problem .
When I use a Timeloop , the first time the VI work very well but the second time Labview crash.
This is the error message :
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
Application Version: 12.0.1.4014
Application Timestamp: 522f27d1
Fault Module Name: lvalarms.dll
Fault Module Version: 5.0.0.49154
Fault Module Timestamp: 4fccee09
Exception Code: 80000003
Exception Offset: 00001779
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
I tried to change the processor (Timeloop paramters ) but I got the same error
This is the VI that I used
Thank you for you help
Message 1 of 11
(4,919 Views)
I don't see an attached VI, can you try it again?
Posting a code snippet should also work.
Message 2 of 11
(4,914 Views)
sorry
 I trie again
Message 3 of 11
(4,910 Views)
Still nothing.  Use the button shown:
Message 4 of 11
(4,902 Views)
I don't have the same buton
this is a picture
Message 5 of 11
(4,894 Views)
I use a other account
sorry about that
Message 6 of 11
(4,882 Views)
no body ?
Message 7 of 11
(4,860 Views)
Can you try to right-click the timed structure inputs and select "Configure input node", then change the processor assignment to Manual, processor 0?
It worked for this guy.
Message 8 of 11
(4,837 Views)
Hi
   thank you for the reply
So I changed the processor ( I put 0). But still not work Smiley Sad
Message 9 of 11
(4,824 Views)
Is there a way you can create a VI that causes the problem but doesn't require any specific hardware to run?
I don't have whatever DAQ device you do so I can't test it.
Message 10 of 11
(4,819 Views)
