lvlib password protection is not working
I can't get password protection to work on a lvlib.  A have created several VIs, out these in a lvlib, and create a source distribution and installer.  I put a password on the lvlib.  When I install it, the installed VIs in the lvlib can still be edited and saved.  How do I set it up so that the VIs in the lvlib cannot be edited?
(3,016 Views)
Accepted by topic author garya505
You have to protect your VIs as well, by setting a password on them as well.
You could also remove the Frontpanel and blockdiagram of the VIs. Make sure you have a backup of your data. These things can be tweaked in the build settings.
Ton
My LabVIEW Ideas
(3,003 Views)
Thanks.
I want to keep the FP and BD, so I'll just put a password on all the VIs.
(2,990 Views)
How can I protect the type defs in the lvlib?
(2,987 Views)
