macOS Big Sur: Labview crashes on launch
Great!!! Thank you!
Message 31 of 40
(3,378 Views)
Para que versiones de Labview funciona?
Message 32 of 40
(3,308 Views)
This solution works on Intel Macs running Big Sur, but it does not seem to work on M1 Macs running Big Sur.
Is there a workaround for M1 Macs?
Message 33 of 40
(3,272 Views)
We have at least one customer report that this solution does work for their M1 Mac.
It does not however work the Apple's pre-release dev kits, which used an Apple A14 instead of the M1, and have a crashing issue not related to this workaround.
If you are still seeing a crash on an M1 with these workarounds in place, that needs further investigation.
If you have the Apple crash report information, that would be helpful.
Message 34 of 40
(3,263 Views)
I'm not sure what you need, so here is the report.  This response is the first part of the crash (to keep response below 50,000 characters).  The next post will be the remainder of the crash report.
Process:               Isaac for Mac [40680]
Path:                  /private/var/folders/*/Isaac for Mac.app/Contents/MacOS/Isaac for Mac
Identifier:            com.company.IsaacforMac
Version:               5.1.0.0 (5.1.0)
Build Info:            lvapp_bcrte-300001~0
Code Type:             X86-64 (Translated)
Parent Process:        ??? [1]
Responsible:           Isaac for Mac [40680]
User ID:               501
Date/Time:             2021-02-03 17:08:25.774 -0500
OS Version:            macOS 11.2 (20D64)
Report Version:        12
Anonymous UUID:        6164D2F2-2B95-ACAD-C4AD-B106E0D8E2DC
Sleep/Wake UUID:       74760620-5442-4061-94A1-59B46FF6B267
Time Awake Since Boot: 12000 seconds
Time Since Wake:       26 seconds
System Integrity Protection: enabled
Notes:                 Translocated Process
Crashed Thread:        9
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
/Library/Frameworks/nipalu.framework/Versions/1/nipalu
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0   ???                            0x00007ffe96392ab8 ???
1   libsystem_kernel.dylib                 0x00007fff20341e7e mach_msg_trap + 10
2   com.apple.CoreFoundation         0x00007fff2046e50d __CFRunLoopServiceMachPort + 316
3   com.apple.CoreFoundation         0x00007fff2046cbf6 __CFRunLoopRun + 1319
4   com.apple.CoreFoundation         0x00007fff2046bfe2 CFRunLoopRunSpecific + 567
5   com.apple.HIToolbox                  0x00007fff2893a630 RunCurrentEventLoopInMode + 292
6   com.apple.HIToolbox                  0x00007fff2893a42c ReceiveNextEventCommon + 709
7   com.apple.HIToolbox                  0x00007fff2893a14f _BlockUntilNextEventMatchingListInModeWithFilter + 64
8   com.apple.AppKit               0x00007fff22bc19b1 _DPSNextEvent + 883
9   com.apple.AppKit               0x00007fff22bc0177 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1366
10  com.ni.labviewRuntime              0x000000010b1e2d5b -[LVNSModalSessionManager_19R runModalLoopAtRoot] + 795
11  com.apple.CoreFoundation        0x00007fff2046d6d9 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
12  com.apple.CoreFoundation        0x00007fff2046d575 __CFRunLoopDoObservers + 549
13  com.apple.CoreFoundation        0x00007fff2046bf69 CFRunLoopRunSpecific + 446
14  com.apple.HIToolbox                 0x00007fff2893a630 RunCurrentEventLoopInMode + 292
15  com.apple.HIToolbox                 0x00007fff2893a282 ReceiveNextEventCommon + 283
16  com.apple.HIToolbox                 0x00007fff2893a14f _BlockUntilNextEventMatchingListInModeWithFilter + 64
17  com.apple.AppKit                       0x00007fff22bc19b1 _DPSNextEvent + 883
18  com.apple.AppKit                       0x00007fff22bc0177 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1366
19  com.apple.AppKit                       0x00007fff22bb268a -[NSApplication run] + 586
20  com.ni.labviewRuntime              0x000000010b1d7159 MainLoop_MacCocoaUI::Run() + 89
21  com.ni.labviewRuntime              0x000000010a58d7e7 MGMain(int, char const* const*) + 183
22  com.ni.labviewRuntime              0x000000010a58dbdc CommonMacMain + 796
23  com.company.IsaacforMac         0x00000001005e8712 main + 258
24  libdyld.dylib                       0x00007fff20391621 start + 1
Thread 1:
0   runtime                               0x00007ffdfffc999c 0x7ffdfff6f000 + 371100
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
1   libsystem_kernel.dylib                 0x00007fff203448e2 __psynch_cvwait + 10
2   com.ni.labviewRuntime               0x000000010b346dbf ThTmoEventWait + 383
3   com.ni.labviewRuntime               0x000000010b30bf0f OccTimerThread(OccTimerThreadRec*) + 95
4   com.ni.labviewRuntime               0x000000010b344c57 ThreadCoverProc(void*) + 183
5   libsystem_pthread.dylib               0x00007fff20376950 _pthread_start + 224
6   libsystem_pthread.dylib               0x00007fff2037247b thread_start + 15
Thread 7:
1   libsystem_kernel.dylib                 0x00007fff2034a1fe __select + 10
2   com.ni.labviewRuntime               0x000000010b344c57 ThreadCoverProc(void*) + 183
3   libsystem_pthread.dylib               0x00007fff20376950 _pthread_start + 224
4   libsystem_pthread.dylib               0x00007fff2037247b thread_start + 15
Thread 8:
1   libsystem_kernel.dylib                 0x00007fff203447b6 __semwait_signal + 10
2   com.ni.labviewRuntime               0x000000010b344935 ThSleep + 69
3   com.ni.labviewRuntime               0x000000010b1f3ad2 CountDownThread(int) + 82
Thread 9 Crashed:
1   libsystem_kernel.dylib                 0x00007fff20348462 __pthread_kill + 10
2   libsystem_c.dylib                0x00007fff202c9720 abort + 120
3   com.ni.framework.nipalu             0x0000000117800884 0x11778e000 + 469124
4   com.ni.framework.nipalu             0x0000000117800d39 0x11778e000 + 470329
5   dyld                           0x0000000200912079 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 559
6   dyld                           0x0000000200912478 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
7   dyld                           0x000000020090cd1a ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 492
8   dyld                           0x000000020090cc85 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 343
9   dyld                           0x000000020090ab82 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 188
10  dyld                                   0x000000020090ac22 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 82
11  dyld                                   0x00000002008fb6a2 dyld::runInitializers(ImageLoader*) + 82
12  dyld                                   0x0000000200906569 dlopen_internal + 609
13  libdyld.dylib                       0x00007fff20392fc0 dlopen_internal(char const*, int, void*) + 177
14  libdyld.dylib                       0x00007fff2038186e dlopen + 28
15  com.apple.CoreFoundation        0x00007fff204a5ebe _CFBundleDlfcnLoadFramework + 132
16  com.apple.CoreFoundation        0x00007fff2050cf51 _CFBundleLoadExecutableAndReturnError + 510
17  com.apple.CoreFoundation        0x00007fff204d4a82 CFBundleGetFunctionPointerForName + 39
18  com.ni.framework.VISA              0x000000011717f966 visaLibSymbol + 54
19  com.ni.framework.VISA              0x000000011717fd52 0x117165000 + 109906
20  com.ni.framework.VISA              0x000000011718475e 0x117165000 + 128862
21  com.ni.framework.VISA              0x000000011719103c viOpenDefaultRM + 668
22  com.ni.labviewRuntime              0x000000010a599713 VInitVisaLib() + 163
23  com.ni.labviewRuntime              0x000000010a5999a0 VisaFindRsrc + 112
24  ???                                    0x00007f886fe7f2ff ???
25  com.ni.labviewRuntime              0x000000010b03aa7d ExecWrapper(void*) + 397
26  com.ni.labviewRuntime              0x000000010b344c57 ThreadCoverProc(void*) + 183
27  libsystem_pthread.dylib              0x00007fff20376950 _pthread_start + 224
28  libsystem_pthread.dylib              0x00007fff2037247b thread_start + 15
Thread 10:
2   com.ni.labviewRuntime               0x000000010b2d28a5 PlatformEventPosix::Wait(int) + 277
3   com.ni.labviewRuntime               0x000000010b3436f0 ThEventWaitWithTimeout + 112
4   com.ni.labviewRuntime               0x000000010b0421b1 DeqPrEQ(PrEQ*, int, EContext*) + 337
5   com.ni.labviewRuntime               0x000000010b03ac97 Exec + 375
6   com.ni.labviewRuntime               0x000000010b03aa7d ExecWrapper(void*) + 397
7   com.ni.labviewRuntime               0x000000010b344c57 ThreadCoverProc(void*) + 183
8   libsystem_pthread.dylib               0x00007fff20376950 _pthread_start + 224
9   libsystem_pthread.dylib               0x00007fff2037247b thread_start + 15
Thread 11:
0   runtime                               0x00007ffdfff96bd8 0x7ffdfff6f000 + 162776
1   runtime                               0x00007ffdfff97940 0x7ffdfff6f000 + 166208
2   runtime                               0x00007ffdfff8047c 0x7ffdfff6f000 + 70780
3   Rosetta Runtime Routines          0x0000000100600524 0x1005ff000 + 5412
4   <translation info unavailable>      0x0000000100f11d88 ???
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:: com.apple.NSEventThread
5   com.apple.AppKit               0x00007fff22d477c6 _NSEventThread + 124
6   libsystem_pthread.dylib               0x00007fff20376950 _pthread_start + 224
7   libsystem_pthread.dylib               0x00007fff2037247b thread_start + 15
Thread 18:
Thread 19:
2   com.ni.framework.UsbPassport   0x00000001176ba57b 0x1176b7000 + 13691
Thread 20:: com.apple.rosetta.exceptionserver
0   runtime                               0x00007ffdfff71238 0x7ffdfff6f000 + 8760
1   runtime                               0x00007ffdfff7b354 0x7ffdfff6f000 + 50004
2   runtime                               0x00007ffdfff7c1f8 0x7ffdfff6f000 + 53752
Thread 9 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00000003054a4000  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x000000030549e0d8  rsi: 0x0000000000000003  rbp: 0x000000000000003e  rsp: 0x000000000000e748
   r8: 0x000000030549e070   r9: 0x000000000000003e  r10: 0x00000003054a4000  r11: 0x00007fff202c96a8
  r12: 0x000000000000ab1f  r13: 0x0000600002acb3a0  r14: 0x0000000000000006  r15: 0x0000000000000016
  rip: <unavailable>  rfl: 0x0000000000000283
Binary Images:
       0x1005e7000 -        0x1005e9fff +com.company.IsaacforMac (5.1.0.0 - 5.1.0) <B333F761-1060-31AE-B161-59121E27F5B1> /var/folders/*/Isaac for Mac.app/Contents/MacOS/Isaac for Mac
       0x10a542000 -        0x10a54cfff +com.ni.framework.NILVRuntimeManager (19.0.1 - 19.0.1f0) <C356C19C-B88C-374E-8DE4-CE1990B7D0B9> /Library/Frameworks/NILVRuntimeManager.framework/Versions/19/NILVRuntimeManager
       0x10a584000 -        0x10b756fff +com.ni.labviewRuntime (19.0.1 - 19.0.1f0) <A62BC124-CF01-3338-9A65-61263B4CA7D3> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/Versions/19/LabVIEW 19.0 Runtime
       0x10ed95000 -        0x10ee1dfff +com.ni.framework.LVSceneGraph (19.0.0 - 19.0.0f0) <D2705648-9017-39B4-AC92-CDDD4F6FC7E1> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/LVSceneGraph.framework/Versions/19/LVSceneGraph
       0x10eea0000 -        0x10effefff +com.ni.framework.osg (3.1.28 - 3.1.28f1) <B90289C4-29CE-36B9-B32E-A266DC68F322> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osg.framework/Versions/3/osg
       0x10f372000 -        0x10f43dfff +com.ni.framework.osgUtil (3.1.28 - 3.1.28f1) <61EF0BA9-62B1-30F7-B673-3DED72C72EB2> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgUtil.framework/Versions/3/osgUtil
       0x10f622000 -        0x10f675fff +com.ni.framework.osgDB (3.1.28 - 3.1.28f1) <AA855C1C-2739-36EE-8C61-2958F0857F11> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgDB.framework/Versions/3/osgDB
       0x10f760000 -        0x10f787fff +com.ni.framework.osgText (3.1.28 - 3.1.28f1) <753358AF-06FB-33AF-BED7-4E784996CEC7> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgText.framework/Versions/3/osgText
       0x10f7f3000 -        0x10f7f6fff +com.ni.framework.OpenThreads (3.1.28 - 3.1.28f1) <201E74FD-2D3C-3A95-A4FB-C4DD6771A773> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/OpenThreads.framework/Versions/3/OpenThreads
       0x10f80d000 -        0x10f825fff +com.ni.framework.osgFX (3.1.28 - 3.1.28f1) <C87CBA10-5F2A-3826-9B60-71C851F2AC3B> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgFX.framework/Versions/3/osgFX
       0x10f86c000 -        0x10f8c8fff +com.ni.framework.osgSim (3.1.28 - 3.1.28f1) <86CC980F-7C52-3BEA-B665-F0A90E78F36F> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgSim.framework/Versions/3/osgSim
       0x10f9a7000 -        0x10f9c0fff +com.ni.framework.osgTerrain (3.1.28 - 3.1.28f1) <B7AE6325-8407-3F77-9FBC-46A55E60B33C> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/osgTerrain.framework/Versions/3/osgTerrain
       0x10fa13000 -        0x10fa26fff +com.ni.framework.niCPULib (19.0.0 - 19.0.0f0) <25118C8C-0803-312F-8561-4926AA831DDD> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/niCPULib.framework/Versions/19/niCPULib
       0x10fa69000 -        0x10fafffff +com.ni.framework.LVMesa (19.0.1 - 19.0.1f0) <7ED6ABC6-6DCB-3B10-89FF-88548C27B953> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/Support/LVMesa.framework/Versions/19/LVMesa
       0x10fca2000 -        0x10fca3fff +com.ni.labview.bundleBroker (19.0.1 - 19.0.1f0) <AFE0F877-268D-3234-A589-58E1D570393D> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/Support/LabVIEWBundleBroker.bundle/Contents/MacOS/LabVIEWBundleBroker
       0x10fd28000 -        0x10fd37fff  libobjc-trampolines.dylib (818.2) <0FECD337-2668-3E38-B494-E75D781B054C> /usr/lib/libobjc-trampolines.dylib
       0x111295000 -        0x1112c3fff +com.ni.framework.niPythonInterface (2.0.0 - 2.0.0f0) <D845B0B9-EC38-370E-91B0-4049BA137B6B> /Library/Frameworks/niPythonInterface.framework/Versions/1/niPythonInterface
       0x114b67000 -        0x1152a2fff  com.apple.AGXMetal13-3 (172.26.2 - 172.26.2) <6361D994-024D-3335-9F50-6902739D307E> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
       0x116ada000 -        0x116c12fff +com.ni.framework.lvanlys (19.0.0 - 19.0.0f0) <689DB2FF-AF36-3227-A4CE-DFC3B56006EA> /Library/Frameworks/LabVIEW 19.0 Runtime.framework/resource/lvanlys.framework/Versions/19/lvanlys
       0x117165000 -        0x11719cfff +com.ni.framework.VISA (19.0.0 - 19.0.0f0) <5AD346BE-9D9E-38DD-BEC3-5FB4D1277F70> /Library/Frameworks/VISA.framework/Versions/A/VISA
       0x11720f000 -        0x117232fff +com.ni.framework.NiSpyLog (18.1.0 - 18.1.0f0) <B376E09D-B87C-3BE1-BDCA-D67B7F8C7EFC> /Library/Frameworks/NiSpyLog.framework/Versions/2/NiSpyLog
       0x117362000 -        0x1173a5fff +com.ni.framework.EnetPassport (19.0.0 - 19.0.0f0) <1E010873-46A5-3D4C-9FB2-DC5EC554EEEE> /Library/Frameworks/VISA.framework/Frameworks/EnetPassport.framework/Versions/A/EnetPassport
       0x117476000 -        0x117484fff +com.ni.framework.EnetSerialPassport (18.0.0 - 18.0.0f0) <B0034B69-68C1-3C0C-9D4E-CAF9B4C03932> /Library/Frameworks/VISA.framework/Frameworks/EnetSerialPassport.framework/Versions/A/EnetSerialPassport
       0x1174b8000 -        0x1174f0fff +com.ni.framework.GpibPassport (18.5.0 - 18.5.0f0) <F96FABEA-9E09-3F0D-9598-1DEE408B1F01> /Library/Frameworks/VISA.framework/Frameworks/GpibPassport.framework/Versions/A/GpibPassport
       0x11758a000 -        0x1175acfff +com.ni.framework.RemotePassport (17.5.0 - 17.5.0f0) <AB67C993-71CF-36FD-AA51-C92CF9267E9D> /Library/Frameworks/VISA.framework/Frameworks/RemotePassport.framework/Versions/A/RemotePassport
       0x117600000 -        0x11761cfff +com.ni.framework.NI-RPC (17.0.0 - 17.0.0f0) <833BEFD9-0F38-0EDB-8147-974F7865645F> /Library/Frameworks/NI-RPC.framework/Versions/3/NI-RPC
       0x11765e000 -        0x117673fff +com.ni.framework.SerialPassport (18.5.0 - 18.5.0f0) <A5764394-7C96-3543-B588-01CFBAE87F5F> /Library/Frameworks/VISA.framework/Frameworks/SerialPassport.framework/Versions/A/SerialPassport
       0x1176b7000 -        0x1176cffff +com.ni.framework.UsbPassport (18.5.0 - 18.5.0f0) <EFA6A113-507C-3440-8EDD-FD4EA8DD2DF5> /Library/Frameworks/VISA.framework/Frameworks/UsbPassport.framework/Versions/A/UsbPassport
       0x11771e000 -        0x117739fff +com.ni.framework.PxiPassport (19.0.0 - 19.0.0f2) <6E538A85-5E28-3E09-850B-5546EFC6BD4B> /Library/Frameworks/VISA.framework/Frameworks/PxiPassport.framework/Versions/A/PxiPassport
       0x11778e000 -        0x11780ffff +com.ni.framework.nipalu (19.0.0 - 19.0.0f0) <90FEE5CB-B176-3070-9F13-6DB1708224D7> /Library/Frameworks/nipalu.framework/Versions/1/nipalu
       0x2008f5000 -        0x200990fff  dyld (832.7.3) <0D4EA85F-7E30-338B-9215-314A5A5539B6> /usr/lib/dyld
    0x7ffdfff6f000 -     0x7ffdfffe2fff +runtime (203.30) <C98E75A6-BDC8-3D5C-B95B-6422005E96D8> /Library/Apple/*/runtime
    0x7fff200aa000 -     0x7fff200abfff  libsystem_blocks.dylib (78) <E644CAA0-65B7-36E4-8041-520F3301F3DB> /usr/lib/system/libsystem_blocks.dylib
    0x7fff200ac000 -     0x7fff200e1fff  libxpc.dylib (2038.80.3) <70F26262-01AA-3CEC-9FAD-2701D24096F0> /usr/lib/system/libxpc.dylib
    0x7fff200e2000 -     0x7fff200f9fff  libsystem_trace.dylib (1277.80.2) <87FEF600-48D9-31C9-B8FC-D5249B2AE95D> /usr/lib/system/libsystem_trace.dylib
    0x7fff200fa000 -     0x7fff20199fff  libcorecrypto.dylib (1000.80.5) <1EB11CFB-ABD7-36DD-97C7-C112A6601416> /usr/lib/system/libcorecrypto.dylib
    0x7fff2019a000 -     0x7fff201c6fff  libsystem_malloc.dylib (317.40.8) <A498D1EF-E43D-310C-84E8-9C0AADA0C475> /usr/lib/system/libsystem_malloc.dylib
    0x7fff201c7000 -     0x7fff2020bfff  libdispatch.dylib (1271.40.12) <AD988EEA-1A2F-3404-9A6E-390FC2504223> /usr/lib/system/libdispatch.dylib
    0x7fff2020c000 -     0x7fff20245fff  libobjc.A.dylib (818.2) <0F399805-A533-3DC9-A951-1D3DF1442BD9> /usr/lib/libobjc.A.dylib
    0x7fff20246000 -     0x7fff20248fff  libsystem_featureflags.dylib (28.60.1) <9CECB43A-094E-3CA9-B730-24DEA1A6DE05> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff20249000 -     0x7fff202d1fff  libsystem_c.dylib (1439.40.11) <4AF71812-4099-3E96-B271-1F259491A2B2> /usr/lib/system/libsystem_c.dylib
    0x7fff202d2000 -     0x7fff20327fff  libc++.1.dylib (904.4) <B217D905-4F9C-3DE0-8844-88FAA3C2C851> /usr/lib/libc++.1.dylib
    0x7fff20328000 -     0x7fff20340fff  libc++abi.dylib (904.4) <3C9FE530-3CD2-3A64-8A36-70816AEBDF0D> /usr/lib/libc++abi.dylib
    0x7fff20341000 -     0x7fff2036ffff  libsystem_kernel.dylib (7195.81.3) <AB413518-ECDE-3F04-A61C-278D3CF43076> /usr/lib/system/libsystem_kernel.dylib
    0x7fff20370000 -     0x7fff2037bfff  libsystem_pthread.dylib (454.80.2) <B989DF6C-ADFE-3AF9-9C91-07D2521F9E47> /usr/lib/system/libsystem_pthread.dylib
    0x7fff2037c000 -     0x7fff203b6fff  libdyld.dylib (832.7.3) <4641E48F-75B5-3CC7-8263-47BF79F15394> /usr/lib/system/libdyld.dylib
    0x7fff203b7000 -     0x7fff203c0fff  libsystem_platform.dylib (254.80.2) <1C3E1A0A-92A8-3CDE-B622-8940B43A5DF2> /usr/lib/system/libsystem_platform.dylib
    0x7fff203c1000 -     0x7fff203ecfff  libsystem_info.dylib (542.40.3) <0C96CFE8-71F5-3335-8423-581BC3DE5846> /usr/lib/system/libsystem_info.dylib
    0x7fff203ed000 -     0x7fff20888fff  com.apple.CoreFoundation (6.9 - 1774.101) <46680730-F553-3297-B602-7A4372447F83> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff20889000 -     0x7fff20ab8fff  com.apple.LaunchServices (1122.11 - 1122.11) <9ACD5692-3B92-3E6E-8B24-56ADCC911556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20ab9000 -     0x7fff20b8cfff  com.apple.gpusw.MetalTools (1.0 - 1) <B1FDD261-7707-3E20-A6C2-99D9AF46356B> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20b8d000 -     0x7fff20d25fff  libBLAS.dylib (1336.40.1) <32291F75-309C-32E5-91E3-989C3DD033C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20d26000 -     0x7fff20d73fff  com.apple.Lexicon-framework (1.0 - 86.1) <2F429EBD-1BD2-3057-B760-8A81546DBD6F> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20d74000 -     0x7fff20de2fff  libSparse.dylib (106) <B889DE4E-7356-3CC8-A13E-68D15E2024DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff20de3000 -     0x7fff20e60fff  com.apple.SystemConfiguration (1.20 - 1.20) <3518EA0E-C32D-32CC-81B9-0F3C83B6430C> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff20e61000 -     0x7fff20e96fff  libCRFSuite.dylib (50) <970D1F7B-5DBD-355F-80D8-C820AA1626D2> /usr/lib/libCRFSuite.dylib
    0x7fff20e97000 -     0x7fff210cefff  libmecabra.dylib (929.1.1) <102A0AD8-D119-340B-B652-B75F0AAB1C7E> /usr/lib/libmecabra.dylib
    0x7fff210cf000 -     0x7fff21432fff  com.apple.Foundation (6.9 - 1774.101) <8D9081B3-3F6A-31A0-9B20-1AE5CD8DD747> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff21433000 -     0x7fff2151ffff  com.apple.LanguageModeling (1.0 - 247.1) <1A05BCD7-232F-3950-936D-EC0F95BA3FB0> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff21520000 -     0x7fff21656fff  com.apple.CoreDisplay (231.3 - 231.3) <6DD6A260-800F-3284-842C-8E4CB9EA47FF> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff21657000 -     0x7fff218cdfff  com.apple.audio.AudioToolboxCore (1.0 - 1180.25) <DEE2C5BA-BFD1-349F-A10A-B10717BA8F7C> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff218ce000 -     0x7fff21ab6fff  com.apple.CoreText (677.3.0.4 - 677.3.0.4) <9A8DC9A0-1A80-3A26-ACA0-A245D3FFF921> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21ab7000 -     0x7fff2215bfff  com.apple.audio.CoreAudio (5.0 - 5.0) <801E2D1E-7EA5-37DA-8F44-B6D7DD3CE5B9> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff2215c000 -     0x7fff224adfff  com.apple.security (7.0 - 59754.80.3) <B377D7C7-EDB6-3737-B492-E9872F4C6469> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff224ae000 -     0x7fff2270ffff  libicucore.A.dylib (66109) <8F8D8A8B-4EE0-3C09-9F45-725A1FBDD38C> /usr/lib/libicucore.A.dylib
    0x7fff22710000 -     0x7fff22719fff  libsystem_darwin.dylib (1439.40.11) <E016D8F7-C87F-36F8-B8A0-6A61B8E4BACB> /usr/lib/system/libsystem_darwin.dylib
    0x7fff2271a000 -     0x7fff22a01fff  com.apple.CoreServices.CarbonCore (1307 - 1307) <B857EADF-D517-34E8-8053-34C0E6695250> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22a02000 -     0x7fff22a40fff  com.apple.CoreServicesInternal (476 - 476) <0DA95074-B315-3B84-B8A3-BAEDC4471A2C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff22a41000 -     0x7fff22a7bfff  com.apple.CSStore (1122.11 - 1122.11) <89992991-8538-380B-B2B8-4EA997CBFDBE> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22a7c000 -     0x7fff22b2afff  com.apple.framework.IOKit (2.0.2 - 1845.81.1) <49AC0177-35A3-3C96-AD9D-3E59923C4761> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22b2b000 -     0x7fff22b36fff  libsystem_notify.dylib (279.40.4) <B2BF20C7-448A-3FBD-A2F5-AB7618D173F6> /usr/lib/system/libsystem_notify.dylib
    0x7fff22b37000 -     0x7fff22b82fff  libsandbox.1.dylib (1441.60.4) <591F41F3-1FE9-354F-A1F9-BC0CC73333DA> /usr/lib/libsandbox.1.dylib
    0x7fff22b83000 -     0x7fff238e5fff  com.apple.AppKit (6.9 - 2022.30.122) <A8124803-CB85-3F33-8674-16B2A021D71C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff238e6000 -     0x7fff23b3afff  com.apple.UIFoundation (1.0 - 727.3) <5A905085-B5EB-3F71-A663-200428E7A5F4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23b3b000 -     0x7fff23b4dfff  com.apple.UniformTypeIdentifiers (633.0.2 - 633.0.2) <2AAE247F-1BA0-3E42-A07B-CBE413747B30> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23b4e000 -     0x7fff23cd8fff  com.apple.desktopservices (1.18 - 1346.3.1) <2144B85E-A433-3F9E-A25D-E8F9D7B6D175> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff23fa5000 -     0x7fff245e8fff  libnetwork.dylib (2288.80.2) <A3F1E999-6D61-32D7-B3F7-67832CEA53CD> /usr/lib/libnetwork.dylib
    0x7fff245e9000 -     0x7fff24a86fff  com.apple.CFNetwork (1220.1 - 1220.1) <04A917FB-DBFB-3432-BA4C-5B860990A420> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24a87000 -     0x7fff24a95fff  libsystem_networkextension.dylib (1295.80.3) <5213D866-7D0E-3FD9-8E1A-03C0E39CEC44> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24a96000 -     0x7fff24a96fff  libenergytrace.dylib (22) <33A9FBF3-A2D3-3ECE-9370-B0ADDE3896DE> /usr/lib/libenergytrace.dylib
    0x7fff24a97000 -     0x7fff24af2fff  libMobileGestalt.dylib (978.80.1) <C4C7A5DC-C3AD-374D-902A-B6DED14FBB67> /usr/lib/libMobileGestalt.dylib
    0x7fff24af3000 -     0x7fff24b09fff  libsystem_asl.dylib (385) <5B48071E-85EB-33B0-AE9B-127AEB398AEC> /usr/lib/system/libsystem_asl.dylib
    0x7fff24b0a000 -     0x7fff24b21fff  com.apple.TCC (1.0 - 1) <2F48471B-68F3-3017-8B18-BEDD4ED5853F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24b22000 -     0x7fff24e88fff  com.apple.SkyLight (1.600.0 - 570.7) <8034EAA7-787C-3A3E-A301-FF90376F247D> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff24e89000 -     0x7fff25542fff  com.apple.CoreGraphics (2.0 - 1463.3.2) <CD74586C-EAE0-3D5A-9B83-AA05E664D1AB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff25543000 -     0x7fff25639fff  com.apple.ColorSync (4.13.0 - 3473.3.1) <A67D9B0A-E9FB-325A-873B-032DAF45C112> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff2563a000 -     0x7fff25695fff  com.apple.HIServices (1.22 - 714) <780B2B09-80A6-32C8-B9E5-024988196E00> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff25a41000 -     0x7fff25e70fff  com.apple.CoreData (120 - 1044.3) <4A41404B-4386-3811-94DE-0675E767E9BA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff25e71000 -     0x7fff25e87fff  com.apple.ProtocolBuffer (1 - 285.23.11.29.1) <58CD91DC-64A9-3A97-AE41-6EA30308D617> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff25e88000 -     0x7fff2603ffff  libsqlite3.dylib (321.1) <5058AACC-054E-34D1-8E67-4C48C2B0814C> /usr/lib/libsqlite3.dylib
    0x7fff26040000 -     0x7fff260bcfff  com.apple.Accounts (113 - 113) <BCB8494A-A340-30A1-928C-9B53E953328D> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff260bd000 -     0x7fff260d5fff  com.apple.commonutilities (8.0 - 900) <8C96D016-2B40-39C0-A51C-9CF687AE7218> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff260d6000 -     0x7fff26157fff  com.apple.BaseBoard (526 - 526) <3A964BB6-7AB8-3B5D-BAF6-40F56D2BA393> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff26158000 -     0x7fff261a3fff  com.apple.RunningBoardServices (1.0 - 505.80.1) <4B9FFFB3-310F-350A-BEBB-AB779BD3F405> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff261a4000 -     0x7fff26219fff  com.apple.AE (918.0.1 - 918.0.1) <9B6B42DB-8768-343B-B10E-A9A5710280CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff2621a000 -     0x7fff26220fff  libdns_services.dylib (1310.80.1) <97EB5DFD-BB41-3834-BF09-1F597D84F324> /usr/lib/libdns_services.dylib
    0x7fff26221000 -     0x7fff26228fff  libsystem_symptoms.dylib (1431.40.36) <BC85B46C-02EE-31FF-861D-F0DE01E8F6CF> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff26229000 -     0x7fff263adfff  com.apple.Network (1.0 - 1) <75C2713C-F0D8-32BA-A839-17A2AE49A061> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff263ae000 -     0x7fff263d2fff  com.apple.analyticsd (1.0 - 1) <4FFF906A-FE79-38F9-B777-AE878A0C99F1> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff263d3000 -     0x7fff263d5fff  libDiagnosticMessagesClient.dylib (112) <20EDB261-69C7-3E4A-8C00-878814186A62> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff263d6000 -     0x7fff26422fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.7.5) <FB7BF527-2D95-3E82-AAD8-D42B33DAC0F0> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff26423000 -     0x7fff264bdfff  com.apple.Metadata (10.7.0 - 2150.7.5) <49187239-597B-31A1-8895-8AA265C818C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff264be000 -     0x7fff264c4fff  com.apple.DiskArbitration (2.7 - 2.7) <ACFCD23E-05DF-3F96-BCFA-E294AAAFD2CE> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff264c5000 -     0x7fff26e4dfff  com.apple.vImage (8.1 - 544.2) <A9DEA5E2-C2EC-3802-BB3B-820F1E3D2D28> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26e4e000 -     0x7fff27118fff  com.apple.QuartzCore (1.11 - 926.8) <04D8759B-1119-3E37-B922-32BDECB7C5D2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff27119000 -     0x7fff2715afff  libFontRegistry.dylib (309) <9E9329F6-7384-3C7F-83E7-D52CD7FFBC09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff2715b000 -     0x7fff2729cfff  com.apple.coreui (2.1 - 690) <6DB427BB-44CA-3002-A3FF-77F0FEFC2A51> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff2729d000 -     0x7fff27388fff  com.apple.ViewBridge (551.3 - 551.3) <9F31CEDB-5B8A-3BAE-A638-E9F352EF4E87> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff27389000 -     0x7fff27394fff  com.apple.PerformanceAnalysis (1.275 - 275) <2E5E666D-EE93-3949-8C76-692FA748D129> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff27395000 -     0x7fff273a4fff  com.apple.OpenDirectory (11.2 - 230.40.1) <333A7F2E-0F3E-37F1-9E1B-69996F5084D2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff273a5000 -     0x7fff273c4fff  com.apple.CFOpenDirectory (11.2 - 230.40.1) <25F138F8-9E55-3749-8271-0FDB275C3E2C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff273c5000 -     0x7fff273cdfff  com.apple.CoreServices.FSEvents (1290.40.2 - 1290.40.2) <6B70B98B-BCC5-3FBE-A6B5-CD0696AA055A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff273ce000 -     0x7fff273f2fff  com.apple.coreservices.SharedFileList (144 - 144) <C861FAD6-D3A5-302C-88AE-B2813F7201A7>
Message 35 of 40
(3,245 Views)
Here is the crash report
Message 36 of 40
(3,250 Views)
This crash is an explicit process abort call in the nipal driver, not in LabVIEW itself.   This driver expects to be able to load the nipalk.kext  kernel extension, and is probably aborting because it cannot do so.  You might be able to find error messages to this effect in system logs.
Rosetta cannot automatically translate driver-level libraries/kernel extensions, so I'm afraid there is no way this app is going to be able to work on M1 hardware in the short term.  NI is considering what would be required to do a native port, but I'm afraid I cannot make any commitments about that or provide any expected time frame for it.
Message 37 of 40
(3,240 Views)
Labview has already faded into oblivion.  Python is killing it and taking its market share for test operations.  NI is the walking dead and they dont even know it.
I am just disappointed because I am now translating all of my labview code into python because of this snark attitude from NI and lack of support for macOS.
Message 38 of 40
(3,184 Views)
It seems that the NI .kext files on Big Sur lead to an excessive amount of CPU use with the kextmanager daemon running all the time - even when there is no need to be running - no application is making use of these kext files.
There should be a way for the update (if there is ever one) to not keep the CPU busy for no reason.
Message 39 of 40
(3,045 Views)
This not work for me.
I have a project run on MAC OS 10.14, recently it was updated to 12.7 and I meet the same error. I tried your solution but nothing happen. I wonder if I recover MAC OS to 10.14, will it work? And do I have to reinstall the Labview?
Message 40 of 40
(957 Views)
