mach3 software and labview
Hi
Im Siya, I want to read the x-axis value of mach3 into labview. Is it possible to do this ?
(5,536 Views)
Sure.  Why not?
If you would like more assistance, please provide some information as to what you are talking about.  What is "mach3"?
(5,528 Views)
Mach3 is CNC software used to control motors (stepping in my case), a breakout board is used to interface the hardware and software. Im using a
Mach3 USB Motion Card AKZ250 breakout board.
the project im working has has to do with motion control and data aquisition using cnc software and ni Mydaq. I have to measure the diameter and profile of an ellipsoid shaped object ( tank dish-end). The X coordinate from mach3 will give me information regarding the diameter. To measure the profile im using an IR distance sensor with Mydaq
(5,520 Views)
You previously asked this question a few months back, and you indicated that thread with a solution. So what has changed? What did you actually do with the information provided to you in that thread?
(5,510 Views)
I wired the cards together thus I can send sent an output signal from the breakout board to an input of Mydaq. Now I want to read a real number ( x axis position) into labview software
(5,501 Views)
