06-03-2004 05:31 PM
06-07-2004
09:58 PM
- last edited on
11-07-2025
03:07 PM
by
Content Cleaner
It sounds like you almost want to use this continue button as both an indicator as well as control. Unfortunately, LabVIEW does not allow both. To work around your issue, use the continue button as an indicator and have it blink when the output of the subVI is finished. Then, use an event structure to take in when the user clicks on the button. When the continue button is pushed, then use a property node to then set the continue button to stop blinking.
The following tutorial should be useful:
Event-Driven Programming in LabVIEW
Also, I have attached an example program that demonstrates using the event structure in LabVIEW with a boolean.
Good luck!
Kileen C.
Applications Engineer
06-08-2004 07:05 AM
