major error with event structure
HenrikDueholm wrote:
Problem occured when working at home after leaving the event dialouge box on my secondary monitor at work (only have one monitor at home).
I'll fix the issue by deleting the line in the .ini file.
It's EditEventsDlgSize=189,1969,775,2749 for me.
OK, that make sense as one possible source of the problem. I have no idea how the original poster got the negative coordinates into the ini file. 😮
There still has to be another mechanism.
Message 21 of 30
(2,833 Views)
I've actually had some issues today with VIs that wouldn't show themselves as well.
I had worked with them on the secondary monitor and they could remember their last position... so I couldn't see them in any way.
I could bring them to my primary monitor using:
WindowsKey-Shift-LeftArrow (windows 7 hotkey).
Using Left/Right arrow on the original issue might also work. I'm not sure though. It might not work on dialogue windows. I've already fixed the event issue on my computer so someone else will have to test if it works.
Also assuming that 0, 0, 0, 0 is defined by the primary monitor negative values might be obtained by not having the primary monitor placed in the top left position?
EDIT: I tried using WindowsKey-Shift-RightArrow to hide the event dialouge box, and then left to show it again. It works! So there's no reason to go to .ini file again to solve this issue.
Message 22 of 30
(2,823 Views)
They usually in up in the bottom right corner in that scenario.  If you look closely, barely grabbable with the mouse.
Message 23 of 30
(2,809 Views)
I've tried that before. That wasn't the case here. If that had been the case maximizing the window with hotkeys would have worked. Instead they were maximized on the monitor that wasn't connected.
All in all this issue might be quite complicated. It is tied to windows in some way. LabVIEW (or something else) somehow convinces the computer that a pseudo secondary monitor is connected (I don't think it is shown in 'Screen resolution').
How I know this is that the windows-shift-arrow commands dont work when you have only one monitor connected... untill you run into something that 'uses' the secondary monitor. Then you can suddenly make windows 'vanish' using the hotkeys. Also i could move my mouse into the non existant area and it wasn't just stuck on the right side of my screen.
Message 24 of 30
(2,782 Views)
What happens if you r-click taskbar and select Cascade windows? It's not a fix, but might be a workaround.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 25 of 30
(2,772 Views)
/Y
Good idea. I might try that next time this happens to me.
Also the windows-shift-arrow hotkeys is a working work-around. The existence of workarounds has downgraded this from a major error to an inconvenience, at least for me. Still NI should probably look into it.
Message 26 of 30
(2,765 Views)
Just developed this issue myself.
Cascading windows did not work.
Deleted the line in labview.ini and worked from there.
Message 27 of 30
(2,713 Views)
It happened to me as well.
LabView 2013 SP 1
EditEventsDlgSize=538,-1292,1124,-512
Luckily for me, it was a quick fix thanked to you guys! 🙂
Message 28 of 30
(2,612 Views)
I also meet the same issue in my LV2013.0f2(32-Bit) and fortunately, I see your post here and either delete labView.ini or replace it with a oldder one does work; Smiley Happy
I had always guess it is due to display issue, the pop-up editor should be there, because I can here beeper once LabView hung up there;
(Windows focus is stuck on that invisiable Event Structure editor panel)
BTW; either disconnect 2nd monitor or change resolution is useless. Even uninstall and reinstall LaBView cannot fix this.
Message 29 of 30
(2,474 Views)
I've had this issue as well today. Found out about the LabVIEW.ini-Key by myself and tried to fix the LTRB-quadruple with success. Now I found this thread only by knowing about the proper name of the ini-key.
For all those who run into this and had to kill LabVIEW to start over: Just press ESC and you can work LabVIEW again. This keypress closes the INVISIBLE dialog and lets LabVIEW run normally again. Just thought I add this piece of information on the subject.
Message 30 of 30
(2,409 Views)
