make vi visible or hide the vi
hi,
I got a question about making a vi (which I programmed) visible or non-visible depending on the situation (which I will determine with a true or false case).
Is there something in labview so I can set some kind of a 'visible' property for self-written programs (like you can set the visible property for controls or indicators)?
The thing is that I want to add an T/F entry (connection) to the vi which determines the visibility of the vi.
thank you in advance,
Marino
(3,018 Views)
Open reference to vi and set property Panel Winwow/Open to False or True.
(3,018 Views)
