making a parameter file
I am using the modbus example.vi to read parameters over modbus.  I want to modify this file to read multiple parameters from, for example a spreadsheet.  Is there any tutorials/examples i can use to do this? or can anyone give me advice?
Message 1 of 12
(5,451 Views)
My absolute favorite method for reading parameters is to use a windows configuration (.ini) file.  There are lots of examples of this as well as Excel.  Go to Help-->Find Examples
-Matt
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 12
(5,428 Views)
Thanks Matt for the reply. was cosidring using a .csv or ini file but i am really confused on how to implement this with my modbus example.  I am really new to labview and struggle. I want to make a table that contains parameter address, address type, etc and feed these values into the bundle in my vi.  Is this possible and if so how do I do it? I can attach part of the parameter list if it would be of help?
Message 3 of 12
(5,400 Views)
 There's a bunch of vi's for configuration files -- all ready made for you.  They really do make your life easier.
If you need help understanding them, look through the examples.  Start by going to help and typing configuration file or ini file.  If that doesn't work, let me know.
-Matt Bradley
Message 4 of 12
(5,375 Views)
Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3478
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 5 of 12
(5,356 Views)
thank you for the link.  It seems to be of use however i cannot open the .vi files as I am using labview 8.0 and the files are created in labview 8.2. Is it possible to get these fgiles in my version?
Message 6 of 12
(5,348 Views)
If you follow the link to: http://zone.ni.com/devzone/cda/epd/p/id/4776 you will see a zip file that is compatable with LabVIEW 7.1. You can open that with LabVIEW 8.0 and compile for version 8.0 using Tools>>Mass Compile.
Message 7 of 12
(5,344 Views)
also it seems i do not have the 'configuration tool pallette used in this link.  Is there a download for it?
Message 8 of 12
(5,340 Views)
forget last comment posted it before reading previous one sorry
Message 9 of 12
(5,337 Views)
I got those files to work.  I attached this to the modbus example vi and i can use it to read one parameter.  How can i modify it to read multiple parameters? I want to be able to further down the line add additional parameters to the config file and not have to modify the labview code.  any suggestions?
thanks again for the links!!!
Message 10 of 12
(5,313 Views)
