making a parameter file
Use additional Read Key vi's.  If that isn't enough, post your vi and the ini file.
(Of course, you'll also have to add matching lines to your .ini file)
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 11 of 12
(631 Views)
thanks Matt,  I have attaches the code,  I have not really done anything with it, its just the modbus example connected to the load configuration & get properties.vi
Message 12 of 12
(624 Views)
