making the x scale on a waveform chart eastern standard time
I am looking for a way to make the x-axis scale of a waveform chart eastern standard time.  I can not get the scale to read the time in the time zone I want when I select absolute or relative time.  I am sure that I am overlooking something simple.  I am unsure where to select the time zone I am looking for.  The eventual use of this chart will be a paperless data aquisition system that will show the data value in the
 y-axis and the time the data was recorded in the x-axis.  Thanks for any help anyone can give.
(2,607 Views)
You could use an XY graph and wire the correct time values to the X-axis.
Cheers!
(2,604 Views)
What time does it display, how are you getting the timestamp, and how are you providing the timestamp to the chart? Have you looked at the shipping example called Real-Time Chart?
(2,596 Views)
Hi Nmayo,
Thank your for contacting National Instruments.  Dennis provided an excellent idea.  I would suggest taking a look at that shipping example.  I believe that accomplishes what you are trying to do.
Let us know if you any further questions!
Kevin H
WSN/Wireless DAQ Product Support Engineer
(2,563 Views)
