manipulating variables
Hi! I believe my problem is a very simple one, nevertheless i can`t figure out how to solve it. Here it goes: i'm reading the output of a millisecond timer which is in a while cycle. What i would like to do is to be able to subtract the new value with the old one, keeping the new one in order to do the same in the next cycle. Here is an example:
cycle 1: ms count= 1000
             output=1000
cycle 2: ms count=2500
             output=2500 - 1000 = 1500
cycle 3: ms count=3300
             output=3300-2500 = 800
cycle 4: ms count=4000
             output=4000-3300=700
As you con see it seems quite simple, but aint no labview expert.. jje!
Thanks in advance!!!!
(3,732 Views)
shift register.  Don't know what it is?  Now is a good time to find out.
(3,726 Views)
Accepted by berper
Hey,
You can use shift-registers, as in the following:
Christian
(3,723 Views)
Thanks guys! That was exactly what i was looking for!!!
Thanks again, see you soon! (can bet for it)
(3,701 Views)
