marker text on Digital gauge
How do I display the text or value on a marker I place on a digital gauge (see picture)
Dan
Dan Shangraw, P.E.
(3,607 Views)
HI ASTDan,
 Could you explain your problem in detail?Generally if i want to put my own marker values..i  will try to change markervalues property of the indicator
Thanks and regards,
srikrishnaNF
Srikrishna
(3,591 Views)
I want to make the text visiable. i.e. +/- 5.  I can move the markers values around.  I want to display what the value is.  I was wondering if there was a property in the control that allowed for this.
Dan
Dan Shangraw, P.E.
(3,572 Views)
Hi ASTDan,
  In the attachment i i put the marker spacing as arbitrary and in the scale.markervalues property to values as -25,-5 0,5,25 and  scale.style property to 0..Please check this attachment..
Thanks and regards,
srikrishnaNF
Srikrishna
(3,555 Views)
Accepted by topic author ASTDan
Ok rookie mistake.
Needed to change the scale display settings (see picture)
Thanks for the help!
Dan
Dan Shangraw, P.E.
(3,528 Views)
