marking xy graph co-ordinates
Hello
Ok I have 2 1d arrays that are bundled together to make an xy graph. I have written a function that will return the xy co-ordinates of all the peaks in this graph. What I would like to do is mark all the co-ordinates on my xy graph that i have had returned to me. My cordinates are in an double format before being written to an array. Is this possible using a property node or such?
Ross
(2,499 Views)
Hi Ross,
see this link please.
Mike
(2,497 Views)
Hi Rossco
I had the look at the above link - thanks for that Mike - do you understand more about where to go with this now, is it working as you had hoped if so great! - if not can you post up the relivant code so that I can take a look and maybe find the best way of doing it in your specific case.
best regards
Graham Green
Sr. Product Marketing Manager
National instruments
(2,473 Views)
