mask and limit testing
When i am trying to use the Mask and Limit testing I am getting " Unable to View Properties"  could you please tell me what will be issue on this.
KJD
(3,667 Views)
I would say off hand that the express VI is corrupted.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,635 Views)
Does this error appear when you first drop the Express VI on the Block Diagram?  Does it not "open up" and allow you to set parameters?  What version of LabVIEW are you using?  What toolkits are installed?  I don't see this error on my LabVIEW 2012 system ...
BS
(3,602 Views)
Hey KJD,
may this document helps you:
Placing an Express VI Causes Error -191231 "Unable to View Properties" - National Instruments
http://digital.ni.com/public.nsf/allkb/9d2d226bb343372886256d6e007521f5
Stephan
(3,544 Views)
