04-23-2009 01:01 AM
hey i am bak with some more quirires and qusetions =((
i am trying to import the matlab codes for the image to be converted to rgb,binary,hsl and grey..bt when ever i innput an image the output is a pure blak image.kindly help me out.i am posting ma vi too.
04-23-2009 08:30 AM
Could be a problem in passing the datatypes and how this "other software" is handling that.
Don't you have the NI Vision Development System to do this?
Christian
04-23-2009 12:48 PM
i am importing the matlab codes..no i am not using the vision dev systems.basically loading an image from the memory and then working on it by using matlab..kindly tell me the way out,plz give me a block diagram too.
thnx
rep soon.
04-23-2009 01:26 PM
In the VI you attached, the array is not wired from the script node to the "IMAQ ArrayToColorImage" VI. What happens when the 'H' array is wired?
Chris M
04-23-2009 11:30 PM
04-23-2009 11:41 PM
04-23-2009 11:47 PM
04-29-2009 12:52 AM
hey,plzzz reply
need serious help
can u tell me a way out so that:
1)i can detect all the horiaontal edges in the image without giving the ROI manually???
2) and then out of all those horizonatl edges how can i extract the first and the second widest horizontal line(max and the 2nd max horizontal edge)..
3)also after extracting those max edges how to calculate their co-ordinates for the ceopping of that image..
plzz do reply..
thnx
04-30-2009
12:41 PM
- last edited on
09-14-2026
05:46 PM
by
Content Cleaner
I can't help you do this in a text based language but we do have vision software that can do what you need. We also have the Machine Vision forum.
Text based programming isn't a strength of mine, sorry.
