Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
maximum value for 2D array
Shades
Member
08-03-2006
12:29 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using 7.1. Does anyone have a subvi made up already for getting the maximum value from a 2-D array?
0
Kudos
Message
1
of 5
(6,685 Views)
Reply
Re: maximum value for 2D array
Kenny_K
Active Participant
08-03-2006
01:13 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
the vi in the Array pallete named Max and Min is a polymorphic vi that you can wire in a 2 d array that ill find the max and min
Kenny
Kenny
1
Kudo
Message
2
of 5
(6,659 Views)
Reply
BrianInTheFores
t
Member
08-03-2006
01:13 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Here is something I wrote in 7.1
Brian
Brian
Find Max value in 2d Array.vi 16 KB
0
Kudos
Message
3
of 5
(6,658 Views)
Reply
altenbach
Knight of NI
08-03-2006
01:18 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Kenny is right. just wire the 2D array to array min&max. No need to jump through loops (sic)
The index output will be an array where the elements correspond to the indices of the Max element in all dimensions.
LabVIEW Champion
1
Kudo
Message
4
of 5
(6,654 Views)
Reply
BrianInTheFores
t
Member
08-03-2006
01:27 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I guess I must like the exercise.
Brian
0
Kudos
Message
5
of 5
(6,644 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
