measure percentage
we need to compare the data that get from daq with this table.
eg, if we get 12.5V , we should get 90% for futhrt calculation.
Message 11 of 43
(2,616 Views)
But actually it isn't a straight line....we want a more accurate value just follow the table....
Message 12 of 43
(2,616 Views)
Did you give a try with what I have suggested?
Message 13 of 43
(2,602 Views)
I get to know linear fit from NI website. But the data we have are not follow a straight line. We want to follow the table accurately. If use linear fit, it may have error. like when voltage eaquls 12.4V, SOC become 85% not 80%...
Message 14 of 43
(2,592 Views)
did you do what christian has suggested....
and as you've said,"But the data we have are not follow a straight line"....again, the key word here: interpolate array
Message 15 of 43
(2,582 Views)
Hi xuan,
as you struggle to follow advices given here and just started to create double posts in the forum (what is really bad!) I will show you a possible solution:
Message 16 of 43
(2,556 Views)
could you please attach the vi here? I try to build the vi like the one you do but some of functions cannot find...
Thanks!!!
Message 17 of 43
(2,524 Views)
Hi xuan,
which function?
SpeadsheetStringToArray? Any of the simple mathematics functions? Or one of those two array functions?
Message 18 of 43
(2,502 Views)
Let us keep it to the basics. All you need is a calibration array of points aanndd "interpolate array". 😄
Message 19 of 43
(2,473 Views)
Really thanks for your help!!!
But I need to get my voltage from a daq. While data for daq and Interpolate 1D are not the same so I convert daq data to a 1D array and use Index Array function to connect the element inside to the Interpolate 1D, but I don't know how to set the index no. of the Index Array.
Do you know how to connect my daq to the program???
Thank you again!!
Message 20 of 43
(2,438 Views)
