measure percentage
I mean the SOC can not be displayed and can not measure the percentage of power left.
Message 31 of 43
(2,569 Views)
You need to be more specific.
Message 32 of 43
(2,537 Views)
Good afternoon
Message 33 of 43
(2,534 Views)
hyhy.pngThis is what I have done now...The charge % always keep 0%. It can not change.
Message 34 of 43
(2,527 Views)
Hi xuan,
use a probe to test the X value you're using to interpolate your points. (Using an ndicator might be a good idea too.)
What value do you feed to the Interpolate1DArray function?
Message 35 of 43
(2,510 Views)
The value I feed is the voltage of battery. One voltage level  got a corresponding charge%. But now I can not get the charge%.
Message 36 of 43
(2,504 Views)
Move that indicator to the output of the index array and report back exactly what the indicator shows. I have no idea why you've ignored the advice about dealing with an array but you need to pay more attention to what people have said.
Message 37 of 43
(2,493 Views)
We cannot use array because we need further calculation. The values are not only 11 but more exact. Like 12.23V corresponding 62%...
Message 38 of 43
(2,468 Views)
Hi xuan,
I really don't know why this will not work for you:
In my (simplified) example this also works nicely! You just need to wire things correctly…
I don't understand this. You can do calculations on arrays too…
Message 39 of 43
(2,462 Views)
Thank you very much for your help...But I can not build the VI that u gave. Can you send me the VI program for me?
Thanks!
Message 40 of 43
(2,438 Views)
