measuring current in ni usb 6009
Hi there,
             Im trying to measure the curren in ni usb 6009, but it is showing wrong values, how do i connect my connectoin just like measuring the voltage postive and negative? and what is the use of external shunt and internal shunt? please do help me, im very struck at it.
Message 1 of 15
(5,218 Views)
Accepted by rithesh
The device can only measure voltage. It does not have an internal shunt do you must provide an external resistor, measure the voltage across it, and calculate the current.
Message 2 of 15
(5,214 Views)
Accepted by rithesh
https://www.sparkfun.com/products/10643
you could buy something like this shunt resistor board and wire it in series with the device you want to measure the current through.
If you then measure the voltage accross this shunt resistor, you can calculate in labview the current flowing through the device that it is wired in series with: V(acrossshunt)=R(shunt value)*I(current) --> V(acrossshunt)/R(shunt value)=I(current)
-pat
Message 3 of 15
(5,180 Views)
Thank you. I have ACS712 i can do with that right for measuring the current ?
Message 4 of 15
(5,156 Views)
Hi Ritesh,
yes, you can…
When creating your PCB don't forget a stabilized voltage supply for that IC!
Message 5 of 15
(5,150 Views)
I have used similar devices from Allegro and they work fine.
The output voltage with no current will be half the supply voltage to the sensor and will change from there as the current varies.
Lynn
Message 6 of 15
(5,148 Views)
Hello, I am doing my final year project.  I am using  NI-6009, part of my project I am required to measure the current using ACS712 current sensor.
I am having some difficulty to calibrate the sensor to read the current as the current is being measured on the multimeter. I will be grateful to get some help
Lynn
Message 7 of 15
(4,050 Views)
Hi Mputu,
It would be so much easier to help when you would explain the problem you have!
And even more easier, when you would attach your current state of VI…
Are you working with Milon?
Message 8 of 15
(4,038 Views)
Good-day,
Thank  you for your feedback. unfortunately I am not working with Milon.
The below is my calibration but the value keep changing, i have no idea why it changing.
I am measuring a constant DC current
Message 9 of 15
(4,025 Views)
Hi Mp06 aka Mputu,
unfortunately you only wrote "image.png" twice, but didn't attached ir inlined any image…
Message 10 of 15
(4,021 Views)
