mergin cluster and dynamic data
hi,
i have a problem of merging a cluster graph with dynamic data graph.the fonction "from dynamic data" & "to dynamic data" don't give me the option for cluster.
i tryed to bild graph from cluster but it's not working.
i tryed to unbundle and re-bundle and nothing happen in the graph.
Message 1 of 26
(6,159 Views)
Hi uzumaki,
the context help for the graph shows you which datatypes you can wire to the graph…
That being said: which datatypes do you want to "merge"/bundle/display?
Mind to attach your VI?
Message 2 of 26
(6,150 Views)
Hi GerdW!
in fact i'm trying to customize the LJstreamUD so i want to merge a signal generated from U3 device(cluster of 3  element) with signal generated by Labview(dynamic data).
Message 3 of 26
(6,142 Views)
maybe the term "merge" is not appropriate.i'd say show two plot from cluster and DD in the same graph
Message 4 of 26
(6,141 Views)
Hi uzumaki,
what kind of "cluster" do you want to plot? Is this type of cluster supported at all? Did you read the context help of the graph?
Did you read my suggestion to actually attach your VI? (If you do please attach for LV2014…)
Message 5 of 26
(6,138 Views)
it's a cluster of double,double,2D array.
for the vi it's said "The attachment's LJStreamUD.vi content type (application/x-labview-vi) does not match its file extension and has been removed."
Message 6 of 26
(6,130 Views)
there it is a screen cap
Message 7 of 26
(6,129 Views)
If i understand correctly: You can build an Array of waveforms and show them on the same graph.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 26
(6,090 Views)
Hi uzumaki,
When you want to create an array of plots all plots have to have the very same datatype. You cannot mix your cluster with waveforms…
Either use waveforms in all places or concat your waveform Y[] data to this 2D array in your cluster!
Try to ZIP your VI first…
Message 9 of 26
(6,085 Views)
hi GerdW & YAMAEDA,
it's a good idea to concat my wavform Y data with my cluster.i have tried it but the square generated signal by LabView appear and the wave signal generated by U3 show up like a specter
NB:
Message 10 of 26
(6,047 Views)
