mergin cluster and dynamic data
Look at my example, build an array of waveforms. Your Sine seems to have t=0 in the waveform, thus all Y values are positioned at x=0.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 26
(2,806 Views)
thanks yamaeda,
i tried your solution but they gave me this message
Message 12 of 26
(2,799 Views)
You can use Build Waveform (+Unbundle) to convert from Cluster to Waveform.
/Y
Qestit Systems
Message 13 of 26
(2,790 Views)
Message 14 of 26
(2,775 Views)
Hi uzumaki,
the waveform datatype does NOT take a 2D array!
Again: you cannot combine incompatible datatypes!
Either stick with your cluster of [x0, dx, 2D-array of Y] or create a proper 1D-array of waveforms…
Message 15 of 26
(2,771 Views)
hi GerdW,
how can i transform 2d array to 1d array without losing data.
I tryed to use index array but it's doesn't work.
Message 16 of 26
(2,771 Views)
Is the 2D array several channels sampled at the same time? If so, you can do the Build waveform in a loop, which'll extract a 1D each loop iteration.
/Y
Qestit Systems
Message 17 of 26
(2,753 Views)
yes,it's a several channels sampled.i did a loop but when i want to connect the  array's size to N it said  that the size of the array is an array!!
Message 18 of 26
(2,742 Views)
i tryed to unbundle my cluster then i transformed my Daynamic Data to an d array of scalars and i bilt a new array (cluster's array+DD' array),after that i bundled all that and that gave me this result :
Message 19 of 26
(2,736 Views)
I have a suggestion that will help you and also help us to help you.  Write the smallest program that you can that (a) gathers data from your device and (b) plots it.  Get rid of all the other plots and as many other things as you can.  Don't worry that it doesn't work, we'll help you "figure it out".  Be sure to attach a VI of your code -- we can't work efficiently from a picture of the code.
Right now, I don't understand what you are doing and why you are having so much trouble (though when I see Dynamic Wires and Express VIs, I immediately start to worry).  Making multi-channel plots of multi-channel data is something that LabVIEW does very well, and (usually) very easily.  Starting with "simpler" code, you can probably figure it out by yourself, but we're certainly happy to help.
Bob Schor
Message 20 of 26
(2,727 Views)
