minimizing the getting started screen
hi,
how can i minimize/disable the labview getting started screen?
when i  close a vi, the getting started screen appears in the center of the screen maximized by default and i allways have to minimize it to see the desktop and double click an other vi.
is there any way to minimize it by default?
(4,837 Views)
See this knowledgebase entry. The title states for Mac, but the .ini entry works for PCs too...
Can I Disable the LabVIEW Getting Started Window On A Macintosh?
showNoNavDialog=True
Message Edited by Phillip Brooks on 07-16-2009 02:45 PM
(4,836 Views)
i added it but it is still the same.i still have to minimize it before seeing my desktop or other folders.
i am using LV8.5
(4,817 Views)
I'm not sure why it doesn't work. I just tried it in LabVIEW 8.6 and it works fine:
[LabVIEW]
defaultConPane=4815
IsFirstLaunch=False
returnKeyAction=True
requireAutoTool=False
maxUndoSteps=16
postScriptLevel2=False
FancyFPTerms=False
defaultErrorHandlingForNewVIs=False
EnableAutomaticErrorHandling=False
(4,798 Views)
Accepted by tonay
ok,
it worked, i made a syntax error.
Message Edited by tonay on 07-20-2009 02:47 AM
(4,778 Views)
Ok tonay. Dont you fee philips link solved your query. :smileywink:
Just a thought . The solution marked by you isnt quiet right. When a new user clicks on the solution he will find
ok,
thanks:smileyhappy:
Doesnt sound right isnt it?:smileyindifferent:
(4,717 Views)
