missing VI's in Probability & Statistics
Hello community,
I am missing some VI's in under the mathematics -> probability and statistics. under i have drops a off the think i got in under the page, but im missing many elements to make an monte carlo simulation...
I hope you can help
regrads from me 🙂
(1,908 Views)
Do you only have "LabVIEW base"? (compare versions)
(1,876 Views)
No, should have the full version thought my school, (my co-students all have the acces.) so that's not the case here, any other ideas ? 🙂
(1,834 Views)
Are these "other students" using the same computer as you and are not having this issue?  Please clarify.
Bill
CLD
(Mid-Level minion.)
(1,832 Views)
No,  but they mostly use windows (like me), and all downloaded the program from the same licens (like me), with the the installation guide.
(1,828 Views)
What does it say in the "help...about" screen?
What does it say in the "NI license manager"?
Did you enter the serial number correctly when activating?
Have you tried reinstalling or repairing the installation?
Did you get any errors during installation?
Did you scan your disk for errors?
Have you talked to the teacher?
(1,817 Views)
Accepted by Lass6565
Can you go to <your LabVIEW directory>\vi.lib\gmath\statdist.llb on the PC in question and see if it has the VIs you need in the directory?  If so, it is likely that it's just a problem with the palette and the rest of your installation is just fine.
If that's the case, you can go to the Tools menu, then under the "Advanced" section you can choose "Edit Palette set", and then finally after that there will be a button you can click to restore all of your palettes to default.
(1,787 Views)
