04-13-2018 04:05 AM
Hello
I'm new to the forum and new in the field, so I'm working on LabVIEW recently and I have a little problem is that when I am following tutorials on the internet they talk about NI-DAQmx to acquire data or simply take a measure so we must Configure the DAQ assistant> Acquire signals > analog input > Voltage and there one is supposed to choose physical channels I believe except that nothing is displayed, there is no list, just writes " No supported devices found "So what's the problem please?
thank you for your answers
Solved! Go to Solution.
04-13-2018 04:31 AM
04-13-2018 04:34 AM
Thank you so much for your reply, so what should i do if there are no supported (DAQ) devices, how can t take my measure?
04-13-2018 04:38 AM
You can'T take measurement if the device is not supported. Which device are you using?
04-13-2018 04:48 AM
i have a NI PXIe-8821, Ni PXe-4139 and NI PXI-4065 it's the first time i'am using this tools, and i find a tutorial (www.ni.com/pdf/manuals/374029b_0114.pdf) in this pdf i just wanted to try it, but when i want to create a new task i can't find the liste that the tutorial is talking about
04-13-2018 04:52 AM
04-13-2018 05:03 AM
hi,
Here is what is displayed on the Max, but I am using the LabVIEW to configure the DAQassistant and my PC is directly connect to the PXie 8821.
04-13-2018 05:35 AM
Select which device you want to use and then on the right click and set task.
04-13-2018 06:37 AM
None of your devices are NI-DAQmx devices.
You need to use the NI-DCPower or NI-DMM to use your devices.
04-13-2018 06:46 AM
thank you, as i said i am new it s the first time i use this tools, so ok i will use NI DMM.
