missing task and channel in DAQ assistant
Hello
I'm new to the forum and new in the field, so I'm working on LabVIEW recently and I have a little problem is that when I am following tutorials on the internet they talk about NI-DAQmx to acquire data or simply take a measure so we must Configure the DAQ assistant> Acquire signals > analog input > Voltage and there one is supposed to choose physical channels I believe except that nothing is displayed, there is no list, just writes " No supported devices found "So what's the problem please?
thank you for your answers
Message 1 of 10
(5,002 Views)
Hi yas,
There are no supported (DAQ) devices…
Message 2 of 10
(4,995 Views)
Thank you so much for your reply, so what should i do if there are no supported (DAQ) devices, how can t take my measure?
Message 3 of 10
(4,990 Views)
     You can'T take measurement if the device is not supported. Which device are you using?
Message 4 of 10
(4,984 Views)
i have a NI PXIe-8821, Ni PXe-4139 and NI PXI-4065 it's the first time i'am using this tools, and i find a tutorial (www.ni.com/pdf/manuals/374029b_0114.pdf) in this pdf i just wanted to try it, but when i want to create a new task i can't find the liste that the tutorial is talking about
Message 5 of 10
(4,975 Views)
Hi yas,
are you trying to setup the DAQAssistent on your local PC or on your PXIe controller?
Which devices are shown in MAX on both of these two computers?
Message 6 of 10
(4,972 Views)
hi,
Here is what is displayed on the Max, but I am using the LabVIEW to configure the DAQassistant and my PC is directly connect to the PXie 8821.
Message 7 of 10
(4,965 Views)
         Select which device you want to use and then on the right click and set task.
Message 8 of 10
(4,962 Views)
Accepted by topic author jazz94
None of your devices are NI-DAQmx devices.
You need to use the NI-DCPower or NI-DMM to use your devices.
Message 9 of 10
(4,956 Views)
thank you, as i said i am new it s the first time i use this tools, so ok i will use NI DMM.
Message 10 of 10
(4,954 Views)
