mmr k20? labview temperature reading
Does anyone have any experience or knowledge of being able to read temperature off an MMR Technologies K-20 Temperature Controller?
Thanks!
Message 1 of 20
(5,976 Views)
Hi sk,
This thread also mentions the MMR K-20.  Some of the suggestions there might be helpful for you as well.
Hope this helps!
Adam W
Applications Engineering
Message 2 of 20
(5,957 Views)
Can Anyone attached the GPIB command for controlling MMR K20? I am looking for it.
Message Edited by cheyne on 06-23-2008 11:01 PM
Message 3 of 20
(5,795 Views)
Cheyne,
You should be able to find these commands in the user manual for your device.  This thread is over 2 years old, so there is a good chance it is no longer monitored by the people who posted here previously. The manual would be your best bet, I couldn't find any other mention of people using the MRR K20 except on this thread and the other linked above.
-Marshall R
Message 4 of 20
(5,767 Views)
Helloo guys.
I know this threath is very old.. but I REALLY need the K-20 MMR labview driver.
Is so anoying my k-20 only works with the original software made in 1993, and is imposible to adapt the program to a nowadays computer.
Please I would really apreciate a any VI or PDF with the GPIB commands ( since the ones in the manual are only for reading, not controlling )
Message 5 of 20
(5,523 Views)
started a new thread here
Message 6 of 20
(5,505 Views)
Hey guys, I have the original manual for the MMR K20 which has all of the program commands.  I just tried a couple and got them to work but its not perfect since it seems to only respond with an answer after the query has timed out.  (Did the commands in NI-422.2 Communicator).  I'm not sure if anyone is still interested in getting this to work but if so, then just reply to this message and I will scan the manual and post it.
Message 7 of 20
(5,239 Views)
Hey I've created a labview program that allows you to monitor the temperature on the K20 and then set it just like in the original program.  Let me know if you want in on it
Message 8 of 20
(5,154 Views)
Hai,
Please post it across. In the future it may help lot of people.
Mathan
Message 9 of 20
(5,134 Views)
Hey, hope this helps some people.  Its not perfect but let me know if you have any questions, I'll post updates as I improve the software.
Message 10 of 20
(5,086 Views)
