mmr k20? labview temperature reading
Hey guys I went and commented a lot of stuff so if you want to change anything you can.  I forgot to mention, use at your own risk.  But I'm assuming the only way you can hurt your tool is by overheating the stage the current set limits are at 408 to 20 kelvin.
I'll post my code that uses the Keithley 24XX to make Richardson plots for schottky diodes.  This should be a good base for a lot of temperature vs current/voltage graphs.
Message 11 of 20
(1,720 Views)
This is essentially the same as the last one I posted except that it allows for a 1d array of temperatures to test.  Once it reaches the temperature it sources current or voltage and then measures the current, voltage and resistance.  After the measurement it will then move on to the next temperature.  You can use the temperature and the current to find the nonideality factor of schottky barrier using a simple Richardson plot.  Just like the previous version this allows you to save each run in a new column and I found that if you save the file as something.xls then you'll be able to open it right up in excel.  Hope this helps someone, let me know if anyone has any questions.
Message 12 of 20
(1,706 Views)
can u please upload the original maunal of k20....
Message 13 of 20
(1,588 Views)
Sure, which one would you like?  There is one on how to setup the hardware and another I believe on the software.
Message 14 of 20
(1,587 Views)
Thanks for your reply .... Actually, I need to use the compressed nitogen and k20 temperature controller in the cryogenic stage to make temperature range from 90k to 350k. And, I have no idea how to do it ..... if u suggest me any maunal, reference or the k20 orinigal manual ... that really helps ...
Message 15 of 20
(1,579 Views)
I just finished setting ours up so if you have any questions feel free to ask but the manual should cover most of it.  Also if you want quicker responses check with MMR Technologies.  I'll try to post the manual later this week when I get a chance to make it into lab.
Message 16 of 20
(1,577 Views)
 thanks for the response ..... Would you knid enough to post the original manual ..... i didnot find it ...
Message 17 of 20
(1,571 Views)
Hello DrNo23,
        Would you mind to tell your e-mail address? I have some quary about the k20.vi software that u posted. I will really appreciate if you send me ur email address.
Thanks a lot for everything.
Tanjima
Message 18 of 20
(1,558 Views)
would you kind enough to post the code that uses the Keithley 24XX to make Richardson plots for schottky diodes. once i opended the file it asking for Keithley 24XX file ...... please let me know the updates ....
Message 19 of 20
(1,556 Views)
You can email me at matstockmail@gmail.com.
Message 20 of 20
(1,547 Views)
