modbus Ethernet
i am working on read data word from Delta Make PLC in labview 2014 using modbus ethernet communication.
is there any help regarding third party ethernet communication with labview.??
(2,868 Views)
Are you using one of NI's modbus library ?
See also here for a discussion about modbus libraries.
(2,850 Views)
You can use OPC server, which helps you to directly communicate with Delta PLC. the link explains basics of OPC http://www.ni.com/white-paper/7451/en/ and this link gives the supported PLCS http://www.ni.com/white-paper/6417/en/.
(2,820 Views)
