modbus Ethernet
i am working on read data word from Delta Make PLC in labview 2014 using modbus ethernet communication.
is there any help regarding third party ethernet communication with labview.??
(3,128 Views)
Are you using one of NI's modbus library ?
  • New
  • Old [link no longer available]
See also here for a discussion about modbus libraries.
(3,110 Views)
You can use OPC server, which helps you to directly communicate with Delta PLC. the link explains basics of OPC https://www.ni.com/en/solutions/industrial-machinery/smart-machine-control/introduction-to-opc.html and this link gives the supported PLCS https://www.ni.com/en/support/documentation/supplemental/07/supported-device---driver-plug-in-list-f...
(3,080 Views)
