modbus io server problem
Hi
I need to communicate with a NI Modbus Demo Box from LabVIEW 2010
My problem is that if I use the Modbus I/O Server as described in How Do I Communicate with the Modbus Demo Box? it does not work. I get error code -196735902 (Modbus I/O server failed to receive any response from the Modbus slave device)
But if I use the MB Modbus Demo Box Example.vi included with the LabVIEW Modbus library it works perfectly... any ideas on what could be happening?
Thank you very much
Guillermo
(2,849 Views)
Sorry, forgot to upload code and a screen capture in case it helps...
(2,845 Views)
