modulating qpsk
sir i am trying to do psk modulation but the inbuilt blocks in labview just give me symbols i have to multiply the real part with cos(omega) and sine(omega) as shown in the attatched png. i couldn't find a specified block for this in modulation toolkit. so i tried to do it manually, i am sending png, plz tell me is it right?
SPSK (t) = Ac cos (2πƒct + Ɵm )------------ sir MT MODUALTE PSK just gives out Ɵm while it doesn't give this 2πƒct term in output. i have to apply all of this equation.
nauman
(4,064 Views)
sir i am sending u qpsk modulator and demodulator block diagrams which i have to implement.
nauman
(4,057 Views)
sir i am really stuck with this problem, looking forward to your response....
regards
nauman
(4,031 Views)
If you attach your VI then it will be helpful to others to help you.So please attach what you have done so far!
Thanks as kudos only:)
(4,026 Views)
sir i have attatched my vi. plz have a look at it i have passed my data from two types of low pass filters, but i think the results are same.  What should i do now to get my transmitted bits again?
nauman
(4,024 Views)
sir i have cleaned up my .vi . so that it can be understood easily. plz sir have a look at it and tell me that can i use PLL for phase detection at the receiver end then afterwards can i be able to get my transmitted bits back from the detected phases?
nauman
(4,010 Views)
sir i am again attatching my vi without triple display. so that most can see it.
nauman
(4,003 Views)
