monitoring unknown tank level and control
Hello
I want monitor unknown numbers of water tank level. but I dont know is it possible to design a wizard that get me numbers of tank and then design them or not? can u help me?
actually, these are process:
1) get number of tank and their properties that are difference between all tanks.
2) show tanks and their levels
3) control input/output valves with a Matlab program
tnx
BR
Message 1 of 29
(4,822 Views)
I highly recommend LabVIEW for your application. It will provide the interface and control environment for your needs. If the tanks already have monitoring equipment it may be possible to interface LabVIEW with that equipment and then display the data. If you need to create the monitoring equipment you could use our CompactDAQ, PXI, or CompactRIO platforms depending on your needs.
If you could describe your needs in further detail I can provide further advice. I hope you have a good day.
Alex D
Systems Engineer
Academic Research
Message 2 of 29
(4,804 Views)
Hi
I really appeciate Alex for his great help.
my project subject is designing a drinking water pumping system. but because of using this frame work for various stations, I need to creat a dynamic software.  it means that the softare recieve the number of pump and reservior from the operator and make the Corresponding schematic of the station. I want to know is it possible to design a wizard based program with LABview and in a step by step maner recieving some data from the operator and finally at the end of the wizard the program generate the schematic of the station with the specified number of pump and reservior.
Regard
Message 3 of 29
(4,795 Views)
Yes, you can create such a "wizard" like program.
You actually need to program it…
Message 4 of 29
(4,790 Views)
Tnx GerdW for leting me know this possibilty in LABview
but could you explain more about it?
I need some detail to start it. i really appreciate if you help me more to understand how such a programming must be prepared?
Regard.
Message 5 of 29
(4,764 Views)
Hi behzad,
As any other programming project too: you need to collect specs, draw a flow chart (on paper!), create the program to follow your flow chart…
Please ask specific questions to get specific answers. As long as you only ask for very general topics all you get are very general answers!
Message 6 of 29
(4,762 Views)
Tnx Gerdw for answering the topic as fast as possible.
I know how to make a general program!
my question is about generating a wizard based program in labview.
the program must be work as follow:
when the Labview code runs. at first step a page with some user defiend parameter is represented. at this step the operator (user) enter the number of pump and reservior and click next. at the next page ( just like a wizard in win xp) the user enter the specific parameter of each pump and ... at the final the wizard closed and the main page of the program represented with the specified number of pump and reservior. and the iterative main code manage the program.
Regard.
Message 7 of 29
(4,760 Views)
Hi behzad,
use a tab control to implement your "pages". Hide the tab "handles" (don't know their English name) and switch the pages programmatically.
Using a small state machine might help too…
Message 8 of 29
(4,758 Views)
tnx GerdW
other friends have any more suggestion?
Message 9 of 29
(4,752 Views)
subpanels, moving visible panel/pane area, calling subVIs, playing with visibility of controls, …
What else do you want?
Message 10 of 29
(4,749 Views)
