monitoring unknown tank level and control
thank u GerdW
can u tell me how can I use of visibilty of an object? for example, I Have 5 water tank but I want see just 2 of them. user Enter 2, and 3 water tank invisible.
Message 11 of 29
(1,563 Views)
Hi behzad,
when you have more than one instance of the very same indicator you should use an array…
Use an array of "water tanks" and set the number of visible elements using a property node!
Message 12 of 29
(1,561 Views)
Hi GerdW and tnx
I used Array, but Array cant output binary number to control more than 1 object. can I set to binary numbers?
Message 13 of 29
(1,557 Views)
Hi behzad,
How is "water tank level" related to outputting binary numbers?
When you have numeric controls you can set them to show binary formatted number in their property dialog (when they are using integer represantations!).
Message 14 of 29
(1,555 Views)
tnx,
visibility block input of water tank is true false or binary format. I cant find binary format for an array, can u address me please?
Message 15 of 29
(1,553 Views)
Hi behzad,
to requote my post: "set the number of visible elements using a property node!"
The number of elements is NOT a boolean value, it's an integer…
Message 16 of 29
(1,566 Views)
No, i want invisible some of object(some of tank) in running program. each object has invisible block that active with a boolean number.
Message 17 of 29
(1,564 Views)
Hi behzad,
you need to wire a boolean wire to each "visible" property node…
Please attach a picture so we know waht you are talking about!
Message 18 of 29
(1,562 Views)
I attached the picture.
we dont know the number of tank, result, I want user select invisible tanks with an array with zero one boolean number.
Message 19 of 29
(1,556 Views)
Hi behzad,
when you want tu use this array to control visibility you should make it an integer array…
Use ">0" comparison followed by IndexArray to get your bits!
Other approach: use a scalar integer numeric input, set it's display format to "%b" and use "number to bool array" to get your boolean array controlling the visibility…
Message 20 of 29
(1,553 Views)
