more event cases in a event structure block
Hello!
I'm using a event structure block and I'm describing an event case. I want run the case only if a boolean control turn to up (to ON) not to off.....if I use value change the case run in both cases......how can i describe the case in this way?
Thanks!!
Larson
(2,810 Views)
you can use the value change event! You only have to put a case structure in the event case with the new value at the selector ant the code to execute in the true case.
Ciao TPoint
(2,808 Views)
Hi
TPoint is right - just use a case structure.
I just wanted to make TPoint aware of not posting *.bmp. If you attach pictures, please use smaller file types (e.g. *.jpg, *.png).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,803 Views)
Hi Thomas,
I've checked it. It takes to long to display the picture..
Ciao TPoint
(2,801 Views)
Ok thank you!
I've tried to do something similar in this way but i tried to put the event block inside the event case.....
Thank you very much!!!
LArson
(2,792 Views)
