more speed using cursors on a XY Graph
Hello!
I'm using cursors on a XY graph. With XY graph's node property I obtain the x cursor value, and using an index matrix I obtain the name of this point from a string matrix. I return this name to XY graph through its property nodes.
But I don't know it spends time, it's not instantaneous. An operation as simple as this I think it colud be fastly, someone knows how??
Thanks!
Larson
(2,838 Views)
You are right, it should be fast. But without a look at your code, there is few chances that you will receive much help. 🙂
Try to build a simplified vi and see if it still shows the same behaviour. Then post it here.
Chilly Charly    (aka CC)
(2,832 Views)
ok!
I'll make a simplified .vi and i'll post it.
Thanks!
Larson
(2,828 Views)
Hi Larson,
did you resolve your question??
Regards
Diego M
(2,794 Views)
Yes.....i resolved my problem
Thank you very  much diego!
Larson
(2,758 Views)
