motor control by serial port
Hi GerdW
sorry for delaySmiley Embarassed.
the point for using type cast is that i have heard that Labview just send/recieve string so all datas must be converted to this type.
AVR can recieve each type we send, the main is LV.
I have closed the serial port at the end. it is out of the while loop and i have thought that it is kind of a routine in working with visa.
as readen befor byte at port is used for recognizing number of bits. do you think it is not needed?
please help me.
waiting for your answerSmiley Wink
thank you!
Message 21 of 23
(578 Views)
still waiting!!!Smiley Frustrated
Message 22 of 23
(552 Views)
Hi Deovalente,
VISA is using a string for sending/receiving data. But that string is just a "container", you may see it as an array of bytes. And those bytes can contain whatever you need to transport...
Don't knw which "routine" you're talking about.
BytesAtPort gives number of bytes in read buffer, as the name says. No "number of bits" to expect here...
Message 23 of 23
(545 Views)
