mounted-to-UNC filename utility
Greetings ... I am operating in XP and LV8.5.
Is there some kind of utility or DLL call which lets me input a string with the name of a mounted directory and output the string value of its full UNC value?
For example: IN --> Y:\place\files\ ...............OUT --> \\user\scratch\place\files
Thanx in advance..
(2,796 Views)
Accepted by modicon
Use the system exec and parse the return of "net use"23542i76D886DBF54D3264
Labview 8.5 attached... You can manipulate this to do the rest of the strip and or appends as you see fit.
Paul
(2,786 Views)
