mouse keyboard windows 10
Hi
I have a program developed using LV2014 on Win7, it uses the mouse and keyboard reading functions (Input Device Control Palette)
Trying to run it on a Surface Pro, it errors out on the keyboard/mouse functions.
Trying to simplify, I ran the Example VI (Monitoring Keyboard and Mouse Activity.vi) it gives an error on the init function. Error -2000000008 (0x88CA6BF8) at Initialize Keyboard.vi: Invalid device index.
That is not even an input to the VI.
I don't want to go tinkering with the palatte VIs, but I'm wondering about compatibility with Win10. I guess officially 2015 is the first supported version. It would be inconvenient to have to upgrade the whole application for this one little feature... I don't really even have anywhere that I could load a LV2015 installation. I don't have enough hard drive space for another virtual machine!
(4,089 Views)
Hi Bauer,
I ran the example on my laptop that's running windows 10 (LV2014) and it worked fine so I don't think it's windows 10 issue. Are you using a physical keyboard with the surface or just the onscreen one?
Dan
Daniel Harryman MEng
CLA, CPI
(4,035 Views)
Which Surface Pro, and which Operating System?  I have my own "suspicions" about the Surface Pro not being 100% compatible with the "Windows PC model" that LabVIEW uses ...
Bob Schor
(4,025 Views)
Hmm not sure which one, it's a brand new one that the end user provided.
It has a keyboard that connects to the tablet via some magnets? I guess it is bluetooth, but not sure. Win10 makes it all so automatic.
I have built a LV15 virtual machine so I'll try it and hopefully it helps.
Do you think a different Win10 tablet like an HP or ASUS would work better?
(3,993 Views)
Hi Bauer,
Try the example with a physical mouse and keyboard connected to the tablet. The VI calls lvinput.dll and requires device ID as an input. Without physical mouse/keyboard, I don't think it will work.
Ren H.
Applications Engineering
(3,959 Views)
Good news! It ends up working fine in LV2015, with the same setup as used in LV2014 that didn't work.
(3,951 Views)
